SQPpro can solve a smooth nonlinear optimization problem possibly having bound contraints on the n variables x, nonlinear inequality constraints, and nonlinear equality constraints. The problem is supposed to be written in the form:
minimize  f(x)
subject to  lb ≤ x ≤ ub
li ≤ ci(x) ≤ ui
ce(x) = 0.
The constraints functions are ci: Rn → Rmi and ce: Rn → Rme, which means that there are mi (≥0) two-side nonlinear inequality  constraints and me (≥0) nonlinear equality  constraints. Lower and upper bounds can be infinite, but must verify l < u. The functions f, ci and ce are supposed smooth (at least first differentiability is required), but may be nonconvex.
